Studio floor
  • Thread starter Thread starter spottydog10
S
spottydog10
Member
Hi I'm in the process of turning a brick built outbuilding (17'3 x 8.1) into a studio.
A new cement floor is down, a stud wall filled with rockwool and plasterboard finished on ceiling and walls.
I was automatically going to put carpet down but after looking around there seems to be a couple of sides to the argument - carpet vs hard floor.
The room will be for mixing and vocals, no other live instruments and the ceilings, walls and corners will be sound treated. Any views on this please?
Absolutely carpet, in fact, in my studios concrete floors always get timber strips with insulation between then a sheet floor. Cables can be easily pulled through when you need to add them, which you always do, and unless you put trunking behind the wall studs, makes wall gap add-ons difficult. Chipboard or one of the usual cheaper than ply works OK. Then the carpet. The trouble with hard walls but parallel surfaces is that they don't sound nice. They sound boxy due to the reflections. You can treat the walls, but ceiling and floor can produce some odd results. If you put laminate flooring down, you'd end up with a big rug or two, I bet!
Yeah, the plasterer is in at the moment (nice lad but he doesnt half drink tea...) it was like a big drum in there yesterday, reflections all over the place.
I'm gonna bung up some cloud panels for the ceiling as well as the wall treatments.
Can I get away with carpet direct onto the concrete Rob?
I would say the Brick wall would serve you better than that Drywall.
I half agree with you Papanate but I need to soundproof a bit with the neighbours quite close and me chick in her home office about 15 feet away hence the insulation in the walls.
You could of Built on the outside - and kept the brick walls.
I have carpet laid directly on concrete and seems to help deaden the room compared to bare concrete. If it were me though I would try it first and if you don't like the barefloor try some area rugs before committing to carpet.
It's OK, but always cold. It does of course not creak - like the occasional ones I get!
You have a nice room to work with. I'd put down some sonopan, and then click lock flooring, with a couple nice big decorative rugs. I've never used sonopan, but I've heard good stuff about it. It's typically used between floors and inside walls for sound proofing, but I'd give it a shot for a floor barrier, instead of the typical backing material you can buy for click lock floors. It might absorb a bit of vibration.
I find wood / fake wood floors much easier to clean / vacuum etc. You never know, you might want to liven the room up a little.
Just my 2 cents.
EL
I like the wood floors in my studio.....but have to "baby powder" every year or they squeak to the point of being audible in a vocal recording.
Great info, I didn't even have to ask my question as it was already subject above
If you want a rolling office chair, they don't like thick carpet.
Harder carpet tiles might be better. You can get that on rolls too.
My recording spaces have thick underlay and thick carpet, but I sit on drum thrones.
I'm afraid, that my advices are too late for following them. However for the future Studio building (hope, this is not last for you :-)) it is very useful to have the preliminary measurement result of low frequencies room response with the same position of the stereo speakers system at seating point. This really makes the work of future peaks&dips neutralization easier to be done. Of course, it needs to measure noise level first.
25x25mm (or thicker if you can) wooden battens on the concrete. Modern "No Nails" type glues are way quicker than screws but a Hilti-gun is even faster!
Then 19mm flooring grade chipboard but be creative! you can put cables in there and use "dips", mains and audio connectors in trays in the floor. Yes, stick carpet on top but have lift out panels for access. With a bit of planning you can have a 6+ XLR output just where the drum kit sits, a couple of XLRs and a headphone jack plus juice where the guitar/bass/kbds be. CAT 5e/6 shielded cable is a cheap way to get 4 mic lines down one 6mm cable. Put in at least twice as much cable as you think you will need...then a bit more!
"Live v dead"? With some of the flooring board cover some with carpet but seal the other side, varnish say. These can be flipped as absorbers or reflectors. Acoustic guitars often sound better if the player is seated on 4+sqr m of a hard surface. Drums often benefit from being raise a few cms.
Make some "GOBOs" vertical panels you can put around drums and amps to control sound. Get clever. Put acrylic windows in them. Put a row of power outlets and XLRs on it and an IEC socket to a dip. Wheels! ...***T! I wish I was 50 and doing this again!
All up and running now, it's quite cosy and needed lots of treatment, I made the RW3 floor to ceiling panels and I already had a few pre made standard size ones.
On the ceiling above the listening spot is Iso bond which work very well.
I took some REW measurements if anyone can help interpret for improvement purposes.
Tbh, it sounds pretty good in there but if I can do any more before I get back on the musical treadmill I'd be grateful for the advice.
Also, there's a bunch of guitars to go in as well.
  • REWFile.zip
    REWFile.zip
Been wondering about this myself lately, so I figured I'd ask here as well.
I'm in the process of taking a room that the former owners of my new house used as a workout room, and converting it into a studio. I've taken down a mirrored wall and put up what treatment I've already owned, for now, but thinking longer term, my understanding is in a room that will be used for recording (mostly acoustic and electric guitars, some vocals, bass I usually do direct) and mixing, generally if there's any surface you want to have reflective, it's the floor, right?
At the moment the floor is large-ish (18-24") "tiles" of heavy duty, short-ply carpet, over some hard surface (it's a finished basement, so I'm guessing concrete). For the time being that's fine, but as I work on the rest of the room (repaint, possibly add more insulation to the ceiling to cut down a little more bleed into the dining room above, though honestly it's already at an accessible level unless I'm really winding up my amp), is it worth the trouble to take out the carpet and put down some sort of harder flooring, or is it all inside baseball at this point and should my only concern be cosmetic?
Medium sized room, I can post up the dimensions tonight if it would help, but I'd guess it's 10-12'x15-18'.
I'd keep it if it's a decent floor - but I like to put in a suspended floor when I can, purely because I can feed cables under it which makes things much easier when you need something where it wasn't, if you know what I mean. It's also useful to put insulation in if the concrete slab is cold.
I honestly have no idea what's under it... but at some point we're probably going to want to take the carpet off the rest of the finished basement (low risk, as we're on the top of a very steep hill, but it IS a water damage risk) and I guess I can kick this down the road until I do.
It's not a very PRETTY floor, and I'll probably want darker walls when I do get around to repainting... but it's not a pressing concern. More just curious what the acoustic implications are.
