B
		Bargarcs
Yes I'm in northeast USA. The internal ground screening of the cables, and switching instruments, gives me some ideas that I haven't been able to put in place yet (I'm very busy right now). I wonder if a nearby floor lamp would work--it's plugged in, and is my main source of light for my recording activities. I also wonder if my Chromebook (also nearby) would work as a ground, though I'm not sure what constitutes "metal" on a Chromebook (I built my own PC but it's way far away in a different room).Hokay! The two devices you mentioned, the Line 6 and the Zoom are both powered from external mains 'lumps'. These are almost always without an earth connection these days, indeed they might even use a bi-pin fig 8 mains plug?
The consequence of all this is that the recording setup is 'floating' i.e. the audio screens are not grounded. This matters little in many cases but, as you have found, cause hum with a guitar.
I think you are based in the USA? I base that assumption on your mention of a "surge protector". We in UK rarely have need of such things, even quite large studio setup do not use power conditioners*
What you need to do I am sure is in effect ground the screen of the guitar cable (the guitar should have internal screening but that's another can!) This is best done by taking a single wire, anything will do, from a metal part of the Zoom or pod and connecting it to a known, good ground. The mains earth is usually the handiest but you can use a water pipe or the chassis of a desktop computer...MUST be plugged in! No need to be on.
*In some cases these can make hums worse especially the cheap filtered mains distribution strips.
How would you attach the wire from the Zoom to a known good ground? Tape or something?
Thank you for getting back to me
		 . If so it would also serve a great secondary purpose if and when I build my next PC. Something like this maybe?
