J
		JamEZmusic
Active member
guitar tone is good, recording is good. It's just really mid range pronounced and is sitting on top of the mix again dominating it. turn it down and if it's still poking out a little scoop somewhere 800-1500 maybe to sit it down. It's a rhythm guitar part, it's not going to sound the same as cherry pie because there is wailing vocals over that guitar and is mixed in properly probably with a scoop to clear space for vocals. It might be double tracked also, this in itself can make it sound much more like a record. The guitar might even be high passed fairly high and has a bass guitar following the riff for a more consistent meaty low end.
it's a nice exercise to download a multitrack of a song with lots of guitars, and then re-play them with your own amp, it's easy to work out the parts because you can just solo them and then you have a target, and then you can mix them in along side professional recorded tracks/drums etc. You'll learn more doing this than an engineer could teach you in a time frame imo. You'll know you are on the right track if your tracks sound in the ballpark to the reference stuff, you should be able to get a professional mix with your recorded guitars, there is nothing inherently wrong with them, a bit piercy that last one, just tame around 2k a touch aswel. using a de-esser around 2k is ultra common. as is using a multiband at 120-240hz to control those chugs, or boom.
