LazerBeakShiek
It is a life preserver
With hands on the strings is there anything you can touch that makes it go away?
			As Spantini has said.....don't just unplug the fridge. Unplug it only when you hear it running....then go and check for the noise.Hmm i may just try and unplug it really quick and see if it goes away. would be faster to test. Then just plug it back in
nope same touching as when i have it laying down not touching itDoe sit change when you take your hands off the instrument?
I have the guitar plugged in and its making the noise and i am shutting all kinds of things down lol, i'm not that clueless. No change with the fridge unplugged.As Spantini has said.....don't just unplug the fridge. Unplug it only when you hear it running....then go and check for the noise.
Mick
I did this exact thing. i unplugged the wifi and router and a few other things and didnt help. Although i didnt actually unplugg it from the wall wart side only the dc plug side. I should disconnect the wall wart itself from the power.Well, I've made a few pounds diagnosing noise issues, and have some kit to do this - scopes and a spectrum analyser, which I use to detect and usual solve interference issues on marine radio systems. I'm quiet aware of the vagaries of EMI and RF noise sources.
The bass was noise sensitive from new - a fairly common problem with jazz basses, and a pickup swap and the usual sticky copper cavity shielding totally cured it. If you can stop your noise with a lump of metal that's great, but as the noise source path is always a straight line, spend some time localising the noise source - move the guitar and see if you can locate it. Common sources I have found are No.1 Switch mode wall wart style power supplies. No.2 network wifi routers. No. 3 Cheap lighting dimmers.
Screening is a tried and tested tool, and some designs are just inherently sensitive to it. Single pole pickups of the Strat type are the worst because their design is looking for the presence of a disturbing force within it's capture area. As in a vibrating string. This leaves them wide open to any other local electro-magnetic fields and in a way, their doing what they were designed to do. My bass picked up the big transformer in my old favourite amp, so the crude cure was put the amp to one side so when I faced the audience the field from the transformer was at right angles to the pole pieces. That's just impractical. The screening helped, but the front of the coils were still unscreened. The side and back routes to the pickups were screened. A change of pickups was the total cure - not to something ultra good and expensive, but ones recommended as being less susceptible to e-m fields.
Its an acoustic guitar with a dimarzio acoustic sound hole pickup. Its a great sounding pickup just getting this issue. I can place the sheet metal somewhere else. where should i place it? I would have to take out the pickup and test putting it behind it to see what happens. The sheet metal is too big to fit behind the sound hole at the moment. I would have to cut it down. Let me trying taking it out and test that.You mentioned that an 1/8 inch thick piece of aluminum blocks the signal. You never mentioned if it blocks it from both sides of the bass. In other words.....you hear the noise....you move the aluminum in front of the pups...the noise goes away......then in back of the pups/bass body without turning the guitar at all.........what happens? Don't mean to irritate you...just trying to help out. Don't rule out a pup cavity shield install or upgrade.
Mick
Sorry...for some reason I thought it was a bass.
If the pickup is one of those removable types......that would be easy to test. As well.....while you have it out.....test shield just the portion of wire that goes from the jack to the pup. It could be that as well. And...of course.....you've tested different cords as well right? Sorry if I missed that. Any cheap cords I have seem to pick up noises. The best ones usually won't. Hang in there....you'll solve this.
Mick
Junk pickup.the sheet really only works if block the front of the pickup it self it seems.
Yup looks like he knows his stuff. He understands how buildings function holistically. Its a tough task. Sometimes you cant control where it is coming from as it may not even be in your suite.Although this is not about acoustic guitar pickups, it does have some interesting reading about the RFI / EMI noise problem and possible causes in a studio environment.
The poster by the name of 'dbbubba' goes into some interesting detail on the subject.
https://gearspace.com/board/so-much...being-picked-up-humbucking-guitar-pickup.html
