R
RRuskin
Rick Ruskin
The Mackie preamps might be a bit better than the Tascam but it's routing isn't all that great.
I just have had this near mint M-30 just sitting for so long I felt bad. If I could get it configured with those patchbays I'd be happy never touching the Mackie againI was never crazy about the Sonics of the CR-1604…or the construction. Or the I.O flexibility. I like a vintage Teac/Tascam mixer better.
Could I use the Mackie for effects sends it has with the m-30?The Mackie preamps might be a bit better than the Tascam but it's routing isn't all that great.
All depends on what “better” means to you. Sterile comes to mind. And that’s an okay thing for somebody or certain things.The Mackie preamps might be a bit better than the Tascam but it's routing isn't all that great.
I think you’re complicating things by doing that.Could I use the Mackie for effects sends it has with the m-30?
What is the reason for having to hav the patchbays?I just have had this near mint M-30 just sitting for so long I felt bad. If I could get it configured with those patchbays I'd be happy never touching the Mackie again
Cleaner, better transient response. Tascam never made a micpre that had much in the way of "punch."All depends on what “better” means to you. Sterile comes to mind. And that’s an okay thing for somebody or certain things.
The patchbays were to make switching multitrack decks and 15 different synthesizers easier on one mixerWhat is the reason for having to hav the patchbays?
I could see thatI think you’re complicating things by doing that.
This isn't a bad idea. I recorded with the m-30 once and I found it very pleasant. Love the EQ. Like the tascam M-208 EQ but not a noisey shitbox like the M-208I'm sure you could but in your position, I'd probably track with the Mackie and mix with the M30. Or I'd get some good outboard mic preamps, use them to track while monitoring/mixing through the M30.
…I just connected the left & right channels of the cd player to Line In 1 & 2…use channel assign 1 and 2 which seemed to allow me to hear the music in stereo thru headphones without needing
to pan each channel hard left and right as I thought would be required.
I know that cd's are line level, so I was not sure if an amp was really needed to drive the speakers, or if the mixer's preamps had enough gain to hear the music loud enough without needing to turn the faders up too high.
Being late at night, I wanted the sound to be heard louder thru the 'phones, and not too loud thru the speakers, but when I tried adjusting the faders and knobs, I noticed the levels affected BOTH the 'phones and the speakers in the same way.
I tried reading thru the M-30 manual, and in some ways, its very detailed and logical, but in other ways, I wish they had a separate Quick Start guide so that a novice can resolve an issue without it turning into a time consuming effort…
Rather than strain my eyes & brain trying to pinpoint the info in the manual, I just reconnected the M-30 to the speakers using the SUBMIX OUT, instead of the Monitor Out (via Rca to 1/4" cables) and finally success- doing this allowed me to separate the headphone level from the monitor speakers, so that I can adjust them independently of each other.
Hopefully, I can build up some momentum, because there is lots left to learn and do, its frustrating to consume hours to simply do what I described above, but I suppose we all have to start somewhere and you just have to learn by doing.
When headphones are plugged into the M-30's front jacks, my observation is that the Monitor knob has to be turned up in order to get sound thru the headphones, if the Monitor knob is down (off) the headphone knob will not put out any sound at all by itself. The orange pan/gain knobs also increase the headphone volume for the channels that the cd player is connected to.The headphone volume pot controls the output of the headphone out jack on the right front panel of the mixer. The source for that output is the Bass/submix switch next to the volume pot.
