bouldersoundguy
The insert is also post HPF.
Did I read that you are recording from the inserts?
Well the signal would start from the line in then I’d be using the inserts to send the signal back and forth from the recorder. Would this mean that the signal couldn’t be EQd before the recording but only post? That would be unfortunate but not a major set back.
? Not on the diagram I found friend. Be rather good if it was.
The Mackie has direct outputs on the first eight channels. The OP could operate it like an 8-track split console setup until he needed more tracks, then switch to the inserts.
You know what would be ideal? Getting a better, with more inputs mixer.![]()
