Just starting, help please?
  • Thread starter Thread starter lepardman
Would be worth trying straight up first. Good chance you'd need to be thumping the crap out of it to get near maximum output.
Grr!*&^%!!WHAT T;&^%! Can't attach a zipped folder even of files that attach piecemeal!
Whatever, that shows the settings for the UCA202 in Windows. The settings need doing for Reaper (defaults to ASIO which won't work) but I think OP has that working? Just need to get the levels sorted..On it. Brekky first.
Oooo! Did NOT like that!
I rigged the attached clip to come out of my KA6 at about 1.5V max on peaks and the 202* was off scale and sounded horrible!
I had to back the level off (in Sampltude) to no more than +3dBu out of the RCA plugs to get a clean recording. That is a smell under 1V.
If overload into the 202 is the problem and you are going to keep the device, the best solution is a 10k log stereo pot in a tin. You can also rationalize to jacks at the same time.
Yeah, that's usually how it is on forums.
A .zip could contain anything, so most don't allow them.
But you did get the quotes to work. Bloody hell Dave. :D
Oh, that was finger trouble mate, just quoted the wrong bod!
Forgot to say, I found only MME drivers would work with the 202 (ASIO won't of course but I did not try ASIO4all)
