OK, just so you know, I had no idea you were using the CL and it's not your fault. When you put 20 sound guys in the same room, you will get 20 different opinions. LOL!
OK, this is how it works in Reaper. When I arm my track to record, I have the option of selecting either a mono or stereo track. I think you have already been given the answer for your DAW, but if that does not work, check your track when you select your input device to see if it gives you the option of mono or stereo.
I tried to do the same thing and I was told I needed to invest in "Streaming Audio Software" to get professional results. At the time it was like $600.00. I said screw that and just started using Google Hang Outs. Your recording environment will play a huge part in how your mic sounds.
I think you should fix the issue with the l/r channels before you look elsewhere. OBS or your recording environment could very well be the problem.
Will do.
I have heard a lot of great things about the MG series but I have never used them. You also need to realize that the mic you have is rated as one of the best you can use for voice. With that being said, you also need to understand that your recording environment will play a large part of how any mic sounds. Can you give some details of where you are recording at and what is in the room?
