J
Jacob Gurule
OK, first of all, your input signal is way to low. This will cause noise as well. If you look at the pic below, it is almost a -50dbs input level. This should be around a -12db to -18dbs.
So, from the mic to the UM2 into the computer and make sure you have the phantom switch turned on in the back. What DAW or recording software are you recording into? If you have tried everything mentioned in this thread and it still does not work, PM me your address and I will send you a xlr cable. I have about 60 of em.
yes, I am positive the switch is on, and I like to use audacity to record
