JDOD
therecordingrebels.com
I assumed it would work too - seemed obvious to me.
I'll remember that this thread is here and that there's something for me to try to get it to work.
I have a note book with all my songs in an and "to do" list for each one. e.g. *re-track rhythm guitars, *lyrics for last verse etc. One track has "sort out drum MIDI, inc cymbal chokes"
RAMI, I tried that technique you suggested and it didn't work.
It's possible that it doesn't work with any new stuff. The last time I used programmed drums, I think it was an actual physical drum machine, like an Alesis DR something and a few others that I can't even remember any more. But I think that by the time I was recording with a computer, I was using real drums. So my method might only work with the very old shit.On the thing Rami suggested, I do know it works in some other drum programs, but I couldn't get it to work in Superior yesterday either.
I don't know if this works any more. But back when I used to use MIDI and program my drums for some of the same reasons as everyone else: No money for mics, living in apartments, etc....
The way I'd get a "choked" cymbal was to program the same cymbal right after the one I want to choke. I would then turn the velocity (or volume, can't remember) of the second cymbal to 0. That would essentially choke the first cymbal because every drum machine/program I ever worked with doesn't allow the first cymbal to continue sustaining if you add the same cymbal right after it.
Try it and let me know.
Used to do this with actual drum machines ....
Speaking of which, of all the useless old pieces of equipment I have, the MOST useless is my Boss Dr Rhythm. WTF does one do with old tech like that, apart from use it as a doorstop (works well on timber floors because of the stick on rubber pads underneath.)?
At the moment I'm using snare trash, but with the wet on about -20. Cheers, I'll try wide chamber later. You think they all sound like they're in the same kit now though?
