Lt. Bob
Spread the Daf!
we're just not capable of understanding ..... probably no point in trying to enlighten us.
I apologize for our shortcomings.
Nobody has said that here.I have a hard time believing that demagging is just made-up stuff that a bunch of people decided is necessary when it's not.
Does common sense tell you to put air in your tires just in case they are low, but not to check the pressure before you pump more in, or check the pressure after you've pumped more in?there are probably rare instances when heads can get magnetized, and it's a standard practice to prevent these kinds of problems, just in case. That's what common sense would tell me.
My old Ferrograph had a Ferrograph branded damagnetiser. I doubt they had marketing gimmicks in the 70s.
Kind of like your new car coming with a can of transmission leak sealer...with the manufacturer's brand name on it...you know, just in case.
You got me!lol ..... you don't get sarcasm either do ya'?
I apologize to the group.But I have absolutely as much experience in the industry as you do.
And so do some others here.
So talking down to us as if somehow you're THE expert and none of us know anything is crap.
Thanks, I really don't want to be a jerk. I've made my points, and been rebuffed. Certainly, that's counterproductive from my side.If you want to be a jerk about it knock yourself out; but it's not necessary and certainly counterproductive.
Just a thought...might add group 3 (with one member):Let's fight about it some more. I think it's fair to say that there are two camps here:
1. They want to demag on a regular basis because they feel it can only help (assuming done correctly), it's part of the routine, and it's what the manual says to do.
2. They want to question the need for demagging regularly because they don't feel it's necessary on newer(ish) machines.
Jaddie has still not told me how my screwdrivers get magnetised. And no, they dont come from the store like that.
So, according to you, my screwdrivers can get magnetised but parts of my tape recorder cant.
Forgive me being picky here...tape is actually not made to be easily magnetized, or it would be easily erased by stray fields. It's actually fairly difficult to get it recorded, which is what that monster bias signal is all about. Yes, it's easier to magnetize than a lot of materials, but it has to be at least sort of resistant or it won't work as a storage medium.Yes.
It's about the metal, and the magnetic fields involved.
Tape is made to be easily magnetized...to allow it's particles to easily respond to the very small magnetic field coming from the heads which are directly in contact with the tape.
Correct! 1/8" will completely prevent recording, though some erasure may occur from the erase head. A micron or two will actually inhibit recording quite nicely, which is why we have to keep heads clean.The tape recorded parts are made NOT to be easily magnetized by the magnetic field coming from the heads.
I bet if you lifted the tape even 1/8" off the heads...nothing would happen to it (just my guess).
Yup. The field on a head is concentrated in the head gap, less than 10 microns wide, and outside that area the field is impossible to even measure accurately. On a properly operating recorder all fields on all heads are AC, which are actually demagnetizing fields. No magnetic field form a head could ever magnetize any parts other than the tape or the head itself, if the machine is defective.That's why the demags (the good ones...the small ones are a waste of time) are made to emit much stronger magnetic fields, in order to overcome the reluctance of the recorder's metal if it's going to have any effect. Also why you have to watch how you demag when you do, because you can leave much greater magnetism on the hard to magnetize metals, than what's coming from the heads...and then you'll have that much harder a time removing it. IOW...the metal is not easily magnetized by small fields from the heads...but with a strong field, it's possible and at the same time equally harder to remove once there.
