M
mesaboogie5050
Yes, I am using TRS cables. Which is the only way to do it on the saffire because inputs 3-8 to by pass the pre amp you have to use TRS. If you use XLR it will turn the pre amps on. Except on 1 and 2.
I can't tell a noise level difference when I was messing with it. It just simply sounded like one was louder than the other. But I was trying it with an electric guitar, so it wasn't the best test. It just seems like -10 is easier. To know that 0VU is -18. 0vu on my meters on +4 is going a little over -12. So 0vu is very close to yellow and I don't want that. Because when I mix it, I won't have the headroom I want and when I put all the instruments together my master fader will start clipping.
I'm gonna have to figure out a way to record soft acoustic guitar parts without all the noise. I turn the air conditioning off and everything but it will still pick up random things. I may have to hang up some comforters and pillows or something.
The vocals aren't as bad because that's usually a louder input.
It sounds okay in the mixing stage. But it's like I said, when I go to make a master, I have to turn everything up and when I do, all that noise gets turned up with it.
