K
KKB-1204
I have all these units together to try to sync my MS-16 and TSR-8. I think I have all the right cables. If anyone has any experience with this set up I would sure appreciate your help.
I suspect you'll have to have one made for you. There should be a pinout for each end in the manuals for the MIDIizer (and/or IF1000) and the MS16.
I suspect any moderately industrialised town will have a cable-making company. However it might be hard to find one who will do one-off or limited runs.Do you have a link to a company that will makes these?
I know its right for the the MS-16, and the 50-pin cinch connector on the other end is proper for the SLAVE I/F connector on the back of your IF1000.
My cable was custom-made to slave my Tascam 58 to an ES-50 synchronizer. It is the same cable for the MS-16, 388, 40 series, ATR60 series and ATR80 series. It'll work with your MS-16 for sure if it is to be the slave machine. Th only catch will be whether or not the pinout on the cinch connector on the IF1000 is the same as the ES-50. I imagine it is...its a standard protocol, but if you or anybody has a copy of the manual and can post the page with the slave cable pinout I might just have your solution. I sold my 58 and the ES-50 long ago and this cable has been for sale on eBay here in the US for weeks.
I have just discovered that the REC function on my MS-16 slave does not engage when I press it on the TSR-8 Master. I don't know if this is normal or not.
I'd have thought so. It wouldn't be much use for dubbing between machines if they both went into record...
You're talking about on the slave machine? The MS-16 blinks in record ready? But then if tracks on the MS-16 are record-enabled and you put the master machine in record mode the MS-16 doesn't follow suit?
I hadn't thought of dubbing between machines. I am using this to add new tracks to either machine. What instance would one want to dub to another machine while it is synced up? Also as long as tracks are not enabled the record button is not actually recording and the light blinks indicating it is in record ready mode.
The MS 16 being the slave does not go into any REC mode.
