Chili
Site Moderator
I thought that acronym was coined by guys like me. We write TFMs.![]()
I think first you should determine if your REC/PB response on the 234 is correct. If you input a 0VU signal when recording, does the VU meter indicate 0VU on playback? If not, there could be an internal calibration issue on the 234. It's my opinion that most vintage devices of this type and age would require calibration, as most of them have not been calibrated since factory new.
You should also get a nominal 0VU signal when the Input & Output controls are at their "cal" position, often is set with a detent, but if no detent would be halfway between the "7" and "8" volume mark in the knob's travel. If this is not the case, again would indicate need for calibration on the 234.
Then you should verify if your US1800 is looking for a -10db nominal line level, vs. a +4db level. The 234 and most other devices in this class run at a -10dbV line level.
Which inputs on the US 1800 are you using? The line inputs on the back? If so they are +4 SOL. Not sure what the Tascam puts out but it could be -10. I dont have a 234 so I cant just go look at it.
I just wanna know if after all this time....have the tracks been transfered yet?
Heck...if I had a 244 or other 4-track player, I would have gladly done the transfers for you!
Normally, I do everything in 24 bit. I suppose if you get good levels, 16 bit will be fine. The digital noise floor ( the only thing that bit depth affects), will be lower than the noise floor of your tracks, so no harm done.
The only time it will make a difference is if you process a track and save the file with the processing. But there isn't much reason to do that if you are just mixing.
