sweetbeats
Reel deep thoughts...
It doesn't specify, but it's built into the procedure. The measurement is being taken after the tone generator is connected, so it's loaded by default if you follow the procedure.
If I measure that same tone from my laptop I get .2368 So I had to use the pgm master fader to raise it up to .316
So Im not sure if this is gonna be accurate. The tone generator output level is at full as is my laptop volume control so I only get .2368. on the meter.
Got the pgm faders(vu's) to all line up.
Some minor variance on the outputs.Especially pgm 8. That was around .320
Now with the master faders.I go the left outputing .316 or very close. But the right,with the same signal going in,is coming out with .312-ish and the vu meter is reading -1 db. So im guessing this is not bad and I should adjust the meter to 0db even if its spitting out around .311-12 ???
On quick question.Is 400 hz the same as 1000k.?
The reason I ask is that on the service chart on page 1-28 is listing 400hz as the tone in some of the steps that i have already done.
Just a little confusing
