fuzzsniffvoyage
I'm going to be gutting my basement and refinishing it. Does it matter much what kind of insulation I use in the ceiling? I'm planning on doubling up on the sheet rock to help as a barrier from up stairs. And as far as the walls go, I'm going single sheets with insulation behind, maybe a spray in or something moisture resistant. Though I am install a dehumidifier.
I'm painting the floor with epoxy, like the kind you'd paint on your garage floor, and going to use area rugs.
The room is going to be 25' x 35' (rounded) and 8' ceilings.
I have 5k allocated for this renovation. (Including tear out) This also includes running electric & installing lights. The only catch is I must use a licensed contractor.
After the renovation, I have another 1k to use for acoustic treatment. OC 703 or what ever I decide to use.
So at this point I'm mainly concerned with what's inside the walls.
