B
BriGreentea
I found the solution finally. My eq on my master bus was great in headphones and monitors I thought at the time and tried the "kick" preset and sounded 5 times better. I also raised all the track levels way up and in the master I would lower it so the peaks would be in between -6 and -3. Never occurred for me to try this as before I left that alone and had to lower each track so I could have any decent headroom on the mixdown.On the mixdown first thing I did is normalized it to -3. Then added my custom multiband compressor, mastering...and with that function I took the loudness maximizer from 20% to 0 and took the widener I had +40% to -40% and with that and brought the mid peak down a tad and just added a little low and high and customized my hard limiter setting from -.01 max and could boost at least 4 db without distortion. Then saved it with a dithering of triangular 44100 16 bit and done.
