K
kennysmoke
The newer models rival the quality of the new Gibson Traditional's and Tribute's and in many cases are superior...
I would never be taken seriously showing up with a Gibson knock off in a pro band or gig.
if you played well enough you would.
I would never be taken seriously showing up with a Gibson knock off in a pro band or gig. Just like slammer, ltd, squier.
It's totally a coincidence but today i suddenly had a jones to use my $140 Xavier tele thinline (in red metalflake!!!) for my gig today.
Hope people will believe I'm a pro.
I only do about 150 paid gigs a year and only done it for about 30 years so I still need the brand name on my gear..![]()
A real SG is what, $700?
Amortize the difference in cost over the 20 years that you will play it.
Get a real one.
]In the end it's about the music and the amazing rush when a group of musicians are playing so tight that no one is thinking, just being interwove musically and on that same plane. That's where I believe it all really matters.
that's the deal right there. What really matters to one guy in inconsequential to another.None of it really matters ........ in the end it's whatever floats your boat.
The differences in quality of manufacture between 1st and 2nd tier guitar makes are glaringly obvious.
Definitely. My Epi Dot is (I believe) laminated maple compressed wood with lesser quality metals than the Gibsons. With more expensive guitars I can definitely tell the difference in quality, and I doubt an Epi LP is going to come close to my LP Std in quality of materials. But I play that Epi regularly and it does an admirable job of doing what a guitar should do and at the price tag, surprisingly so.
On an instrument that is principally designed to be played amplified there is absolutely nothing wrong with laminates.
i thought Gibson 335s were a laminated top. I don't think they're solid.Yep, but it's a cheaper quality of wood than a solid maple top. An Epi is not using the quality of materials that most Gibsons are.
I'm not trying to say anything is best or worse here, thats just how it works.
Would you say the materials on an Epiphone DOT, generally speaking, are as good as those used on a Gibson ES 335?
