Reaper Question!
  • Thread starter Thread starter Helpmeimanoob
H
Helpmeimanoob
I'm trying to record my vocals over an acoustic guitar track, while it's playing. Now I normally can't hear myself through my headphones while i'm speaking. But when I hit the "Record Monitoring" button located on the individual track window, I suddenly can. ONE PROBLEM! there is about a one second delay, which obviously, is not going to work!
Does anyone have any ideas?
Or don't use record monitoring and just lower your playback volume/raise the mics volume in your software mixer/both. You shouldn't have to use record monitoring just to hear yourself (I don't think).
Without the "Record monotoring" button on i cant hear myself at all (until after the track is recorded)
Just so you know.... 1. there's a Reaper forum below if you have any specific Reaper issues (for the future) 2. this isn't a Reaper problem as such but a general latency issue that's quite common
What interface, and what driver you're using may be useful in working out the solution. I don't have Reaper in front of me but the area you set the buffers is the same area where you actually specify what sound device Reaper is using.
You might want to divulge your computer specs as well - OS/processor/RAM.
Good luck.
Oh sheesh, that doesn't come with software does it. If you mute your acoustic guitar track can you hear your vocals? In other words is it too quiet or just not there?
And have you played with the monitor "Mix" knob on the back of the unit?
Without turning on the Record monitoring there's nothing at all coming through my phones. even when i mute the guitar.
And no, the USB dual pre doesnt come with Software.
But heres what im using...
2TB Harddrive
Yea, im in preferences trying to figure out how to change latency atm... that'll work?
yea, when set all the way on Computer, and record monitoring is on I get that 1 second delay. But with it on Preamp I get nothing at all.
How do I change the latency in reaper? Im looking through the preferences menus and I'm not sure what to do.
My Buffers at 8x1024 samples. which gives me 185 latency. What should i change that to?
Try halving it for a start... see if that works. Experiment. I think mine's set at 256 - there's a balancing act between what your computer can handle and that buffer...
Lol, I don't know anything about that buffering crap, sorry. Come back Henry and Armistice!!
Am I allowed to change the second number? I have it at 2x1024 right now. (46ms) Its a lot closer but still some delay. (thanks for helping me guys, i know im a huge n00b but...thnx)
