Armistice
Son of Yoda
In case you didn't put the previous comments together, a 3m x 3m square brick room is a very difficult space to record in for any number of reasons. This won't be helping your cause.
So what reverb do you use for vocal? I have an effect called metal tank...any good?
Also, with vocal double up, do you use your own voice or other people's? I notice if i just use my voice if it'd harmony that's still ok but if i sing the exact same melody i have this weird robot like song. Why is that?
All is not lost.
First off, I'm one of those who says that if you can't have a studio that sounds great, just try to make it dead and add electronic reverb/presence later. Maybe this comes from spending a lot of my life working in TV studios which are carefully treated to be dead!
Yes, you can spend tons to treat a whole room but a cheap as chips solution is to build some frames using PVC pipe and joints you can buy from any DIY shop. Then, with the pipes as a support, hang quilts of movers blankets over them to make basic acoustic screens. Put one screen behind you when you record your vocal--your mic is mainly sensitive in one direction so, as long as the mic is pointing at you, the worst reflections will be coming off the wall behind you. Work with the screen fairly close to that one way so you're a good way from the opposite side. If your room is really bad, experiment with extra screens, maybe on the far wall behind the mic and/or maybe up to one or both sides of you (but not right by the mic).
Will this be as good as a pro studio where they spent a quarter of a million on acoustic treatment? Nope. Will it be darn close for spending fifty or a hundred bucks? Yup. It'll help a lot.
As far as the technique for this reverb in this song steen hit the nail on the head. Most people don't know how this is really don't. Jus like the above post stated automation. Might want to start looking into how your automation works on your daw.Hi there, and welcome.
The technique on the verses is an automated long reverb tail.
By that I mean, there's a reverb with a long tail, but it's only introduced on certain words and phrases.
The easiest way to achieve this is to have your normal reverb on the vocals and then use automation to increase the reverb length briefly just in advance of key words.
The sound you hear in the chorus is multiple recordings of the main part, but also multiple recordings of at least one harmony part.
I'll admit, I only listened for long enough to get the idea, so I haven't counted them,
but a good start would be to record the chorus part twice, then record a harmony part twice.
Once done, you can pan a main and a harmony some degree to the left, and the other main and harmony the same degree to the right.
Hope that's useful to you.
Now I understand all the parameters you mention, but explaining it...that's a whole nother task. Might need help from the other guys. As others mentioned the type of reverb maybe a cathedral or a long bright hall.Hi guys,
I've checked the mike and I have actually pointed it to the right way so if it sounds bad then it must be the room or my mix or performance.
I mean I don't sing off key but somehow the voice just doesn't bland with the music.
The biggest thing for me is the methods those guys (and you guys) use to produce the voice similar to the "Friend of God" video link I posted earlier. I tried to do vocal double ups and that but somehow it doesn't sound like it.
On reverb, how do you set the parameters so that you can make the instrument is in front of (or rear) the others? The particular software I use has the following parameters:
- Pre-delay
- Mix with early reflection
- Length
- Damping
- Early reflections
- Room size
- Wet
- Dry
What are they and how to use it? It comes with several presets such as Cathedral, Large Hall, Large Hall 2, MEtal TAnk, etc.
Like rgoutte said, I thank you so much for your patience. Hey, I'm a professional musician who sucks at mixing and sound engineering. I know the sound that I'm looking for I just don't know how to get there.
So again, thank you. All of your suggestions have been so invaluable to me.
Nah, leave it. It's beautiful.About the typo's I am on a iPhone the damn thing types what it thinks I'm trying to say. Those on a iPhone know we can't edit the post we post. If u know how please tell me I am easily the laughing stock of the entire forum now.geeeeze lol.
hi guys,
i've checked the mike and i have actually pointed it to the right way so if it sounds bad then it must be the room or my mix or performance.
I mean i don't sing off key but somehow the voice just doesn't bland with the music.
The biggest thing for me is the methods those guys (and you guys) use to produce the voice similar to the "friend of god" video link i posted earlier. I tried to do vocal double ups and that but somehow it doesn't sound like it.
On reverb, how do you set the parameters so that you can make the instrument is in front of (or rear) the others? The particular software i use has the following parameters:
- pre-delay
- mix with early reflection
- length
- damping
- early reflections
- room size
- wet
- dry
what are they and how to use it? It comes with several presets such as cathedral, large hall, large hall 2, metal tank, etc.
Like rgoutte said, i thank you so much for your patience. Hey, i'm a professional musician who sucks at mixing and sound engineering. I know the sound that i'm looking for i just don't know how to get there.
