Farview
There is no reason to back anything off if the main buss is only peaking at -5dbfs. That's fine, you don't need any more headroom at the main buss. There is certainly no reason to back everything down by 15db.
If you are trying to get peak levels of -18dbfs, you are going way overboard with the headroom thing. -18dbfs should be your average level, not your peak level. If your peaks are hitting -5dbfs, your average level is probably just about right.
Also, if you insert the compressor on one of the bottom 2 channel inserts, those are post fader, which will be a problem. Insert it in one of the top ones, then the compressor will act on the prefade signal.
I can know exactly want I might want in a function- I just have to keep looking up which they're called
