Edit
After a few hours playing around, I discovered why Rewind was not working correctly. There are two grub screws that hold the rubber wheel, X, (see below) to the spindle. They had come loose. Thus the rubber wheel would spin but the spindle would not (very hard to see that it wasn't spinning), and the spindle was therefore not driving the cassette. This was easily fixed: the grub screws could be accessed with a screwdriver without having to remove anything except the back cover.
The Problem
I have a Portastudio 144 which has an intermittent problem with Rewind. Play and Fast Forward work well, but Rewind stops and starts as if something is slipping; and when it stops for more than about a second, it then cuts out.
WHAT THE PROBLEM ISN"T
1. The problem does not appear to be connected with a lack of drive due to a worn "toothed" drive wheel. The rubber wheel (call it X) on the Rewind spindle driven by that toothed wheel turns as it should, but if I apply slight pressure to the segmented black plastic bit (call it Y) in the cassette housing, the part that actually turns the cassette, Y will stop. All the while, X keeps spinning. It's as if there is slippage between X and Y. When I do the same for Fast Forward, there is quite a large amount of torque available.
2. The problem does not appear to be connected to loose "counter" belts or a problem with the magnetic disk and Hall Effect sensor. I say that because Play and FF work perfectly.
WHAT THE PROBLEM MIGHT BE
I'm pretty sure that something is slipping in the shaft that connects X & Y, but I can't see how that can be as I assume it is actually a solid shaft connecting the two.
Any suggestions most appreciated.
DOCUMENTATION FOR DOWNLOAD
Also, while I have been refurbishing my three Tascams (144, 234 and 414) as a part of digitising all my recordings, I have also digitised all the paperwork that came with the machines. To download schematics, owner's manuals, and brochures for the three machines mentioned, and also a detailed instruction guide on replacing the capstan and cam belts in a
Tascam 234, as well as other audio goodies, go to ***
Note: this site won't let me post the link. If someone who has more than 10 posts can gmail me at gdburns, I will send the link to you, and I would appreciate it if you could then post the link. Thanks.
