C
C bop a loo bop
Hello All,
Well i just scooped up another 388 that looks great and heads look well too being that they were relapped not too long ago but I'm having two issue's. 1 is that the play/rw/ff/rec funtions will just stop in the middle of whatever function is happening? This happens randomly but can be reset by pushing down on the right tension arm. Just pushing it up won't restart the capstan but down will. Is there a fix for this like adjusting the tension arm's R112 and R212 for rwd/ff. I guess like an overall adjustment. I've searched forum's but haven't found a positive answer except for build up which i didn't see. Thanks!
2. It seems as though the recorded level of most channels is a little bit lower in decibels and has a very faint hint of distortion to it. I'll note that the heads themselves look to have proper wear as far as no cracks or odd shaped wear down as hints of a bad alignment. please help!
I purchased this one out of sure amazement from the first one i got last October. I really really love these machine's and have become very serious about it replacing my computer rig.
Any help on the above two issue's would be greatly appreciated and sorry if this was discussed earlier.
Cheers
C Bop
Cheers
C Bop
other channels seem fine but def needs an alignment. Any thoughts on these questions guys?? Thanks!
