B
		bleachboy
Member
Hi everybody,
I'm looking to have a little bit of help regarding two (opposite!) transport issues on two Tascam R2Rs, if you'd be so kind !
TSR 8: I have gotten inside that machine quite a lot now, and have used it without major issues for a couple of years now. The main thing is that I can't stop the tape when it's in "fast" REWIND mode. In other words, when I want the tape to rewind to a precise previous location (whether LOC 1/2 or RTZ), it does it without problem as long as that location isn't too "far behind" the location where the tape is. It rewinds moderately fast and stops smoothly where I want it to. If I have to do a "medium" REWIND, meaning going from one point to another location a little farther back on the tape, the STOP switch works but it takes a lot of time for the reels to slow down and stop. Sometimes it even rewinds way too much, then stops and fast forwards to the intended LOC point.
However, if I'm at the end of the tape and I either want to return to zero or rewind at some location at the beginning of the tape, REWIND starts moderately fast and gradually gains speed (which is normal, I think), but when it's in fast REWIND, it can't be stopped and it's a bit frightening ! The STOP/PLAY/REW/FF switches have no effect at all. The only way I can stop the tape from rolling is by turning the TSR 8 off...
I have read somewhere that there is a R106 screw on the board that I can use to adjust the REWIND tension. Am I on the right track there ? Any advice on how to do this ? I have never ever touched anything on that board and it does frighten me a bit !
58: The issues I have with this deck are quite the opposite. REWIND is very slow. When the takeup reel is full and I hit REWIND, it starts fine (fast), but the fuller the reel on the left gets, the slower the REWIND is. It is as if the weight of the tape itself puts too much force on the motor and therefore it doesn't have enough torque, or something like that. I have however never opened that beast of a machine, I just bought it !
I will add that both of these issues occur when using a fresh SM911 tape, with both tape paths thoroughly cleaned.
Thanks a lot in advance !
Louis
Louis
