T
theD1CKENS
*insert clever title here
what's the deal with matching(or mismatching) ohms? it's never come up for me until recently.
I have an Epiphone ValveJunior amp(5 watts) and a Crate Blue Voodoo cab(200 watts, I believe). the amp has 3 outputs on the back at 16, 8, and 4 ohms, 16 being the one run into the amp itself by default(it has it's own 1/4" jack that can be disconnected, which I do when I run the cab). the cab has a selector on the back, which can switch between 16, 8, and 4 ohms.
when I use just the amp, I leave the 1X12 connected to the 16 ohm output. when I run the cab, I disconnect the 1X12, and run out from 4 ohms into the cab, with the switch set to 4 ohms, also. this seems to give me the most volume, and allows me to push the amp harder before it starts to REALLY break up...I think
basically, what's the difference? I want to get the most out of this set-up, volume-wise, tone-wise, and otherwise...without blowing anything up. I haven't really read the fine print on the back of the amp, but I'd guess it's irrelevant which output I use. wouldn't the factory speaker be able to handle any of its own outputs with no trouble? same deal when I run the cab, as long as amp and cab are matched, does it matter?
on an unrelated note, how the EFF does a tiny little 5 watt amp have enough juice to push a 200 watt cab?! it doesn't seem to have trouble pushing 2 cabs, either, full-stack style, tho I have no idea how many watts the other cab is. not mine, sounds like poo and don't need that much amplification, anyway.
apologies for the long post
