Shadow_7
Well you can always try the standard M$ methodology and see if that helps. a) reboot, if that doesn't work, b) re-install, if that doesn't work, c) upgrade, if that doesn't work, d) .... .. . . . . . .
If it came with your computer and it's fairly new, it's probably some form of hda-intel soundcard. Which is almost always quirky with it's drivers. Otherwise I've never heard of IDT, is that like DHL / UPS / ....
Integrated Device Technology. (i.e. CHEAP / per unit / aka integrated)
IDT - Integrated Device Technology - High Definition Audio
Go into Sonar and look at the audio properties. The default buffer size, I believe, is 512k or 256k.
Increase it to 1024 or 2048. This should reduce stuttering at a cost to latency.
As for the mic, troubleshoot by using a different one with the same channel, effects, etc.
Hang in there, OP. We'll figure this out.
Hmmm. This makes me suspect a driver conflict. Do you have any plugins active during playback? If so, does removing them help?
Also: Vista sucks. I have had similar problems in the past, and was able to resolve the issue with a OS reinstall/reformat. Sonar can be picky about the order in which you install drivers. Do not disable onboard sound in the BIOS at setup.
Sounds like you are on the right track, OP.
Ditch the WDM driver and switch over to the ASIO driver.
Ploytec USB ASIO (USB 2 Audio) Driver 2.8.40 For Win XP, Win Vista & Win 7 (32-bit & 64-bit) | AvaxHome
Also, I don't see anywhere in this thread where you have explained the sample rate or bit depth you are using, and I don't think anybody else has mentioned it either. No need to record at higher than 48kHz sample rate. If you're trying at 96k that is gonna be a huge problem with the hardware you are using.
Record at 48kHz and 24-bit.
