R
		ryserhippo
setup: on a mac with an apogee ensemble as my interface > all 8 outputs going DB25 to a Summing Amp. The SPIDF output on the ensemble is going to the Coax input on a benchmark DAC1 for monitoring. I then have the summing amp output plugged into inputs 7/8 on my ensemble
Everything seems to be working...until I listen to what's going through the summing amp. It sound like it's phasing, all my low end/mid range is getting eaten up...but when I pan a stem hard right or hard left, it sounds AMAZING...except the problem is, it's panned hard left or hard right.
How do I get what I hear when its panned, when I have the stems (audio channel) centered?
A little more info: Logic 7.2 is my DAW I separate - drums/bass/guitars,synths,(mid rangy stuff)/main vox & beegees - over the 4 stereo pairs.
Output 1-2 = Drums
Output 3-4 = Bassy bits
Output 5-6 = Guitars, Synths, etc.
Output 7-8 = Vox, etc.
I then set-up an Audio channel with the input recording the summing amp (input 7/8) and output 9/10 (going to my DAC1)
Any help would be great appreciated
Thanks!
Output 1-2 = Drums
Thanks!
