Actually...I don't think they are motorized...it's all MIDI fader/volume position info...though they are still different than the straightforward faders in the 3500.
I use to use an external automation package with my 3500 (Niche ACM), which basically did that same thing that the 3700 can do via MIDI, and since it was also available as a computer app, there was a graphic user interface, much more user-friendly than the basic 3700 automation hardware....but it's still nice to do basic automation stuff if you really need it.
I only used my automation package a few times, and found it was much easier to just “work the board”...it's not like it’s a large format console with a 100 channels to have to control manually!
Besides, since I now use a DAW for playback and mix through my 3500...these days I rarely move any faders when mixing down. I usually pre-set all my levels in the DAW via software (not the typical DAW volume automation..I do it with Object manipulation in Samplitude)….then for the mixdown, I just sit back and listen, though maybe I nudge a fader here and there occasionally.
Yes, I am in NY...actually further south than you...but still, it would have been a ride and time/effort to go pick up the consoles...I just wasn't that motivated since I have a fully working one along with spare modules and other parts.
AFA the meter bridge extension...I never bought the one for the 32-channel , I just meant that I saw it for sale on eBay at the same time the two boards you bought were on sale...when I was considering the idea of converting to a 32-channel.
My 24-channel has the meter bridge from the day I bought it new back in 1990.
They are decent boards, mine has been working without a hitch for 20 years!!!
(Did I just jinx myself?)
Anyway, I believe the 3500 has better/simpler grounding (less issues) than the 3700 with its extra wiring and MIDI automation.
I just don't think the automation is a major bonus. If it was VCA/moving faders instead of MIDI volume...that would be different.
