Boy am I glad I found this thread! Really nice job on the cleaning, Tim!
I have an M3700, USA version, no +4 kit, 32 channels and full meterbridge. Couple of things I can clear up about the automation, since it came up: it's VCA, no moving anything, but it will control fader moves, channel mutes, EQ in/out, and aux mutes. It can function in dynamic and snapshot modes, the former sync'd to MTC or SMPTE with dip switches that also dictate FPS. I use dynamic mode for automated mixing and I sometimes use the snapshot just for recalling between sessions so my life doesn't get too knocked off balance every time a studiomate musses up the fader positions while I'm not around (they're all ITB people!
) Basically, I take a snapshot of all the switch and fader positions so when I come back to the mix to find some faders knocked around and buttons bumped I can load that snapshot, put the computer in Null Mode and the switches will set themselves where they should be and arrows next to the channel faders point to where they should be moved. The global auto modes are typical Read, Write, Update, and Null (the latter is a handy touch both in dynamic and snapshot modes), and you can also put individual channels in and out of read/write with a button next to each fader. The automation on the M3700 is IMHO actually pretty pleasant to use for what it is and was very easy to learn. Only complaint is that the VCAs add noise to the path and they also dull the high end a little bit--but the noise that automated mutes and fade downs prevents more than makes up for the noise added by the VCAs. I'm just glad Tascam made the system bypassable so channels you're not automating are not affected!
Anyway,
my M3700 is fairly clean (previously lived in a church from what I know) and it's fully functional and free of scratchiness, but it's fairly noisy and most likely hasn't been recapped. I had the PSU serviced when I bought it but I don't think its caps were part of the repair--I'd have to check the invoice.
Any thoughts on what can be done to quiet this guy down? Eventually I will trade this puppy up for a large format console so I don't want to put more cash into it than I have to, but for now I'm using it and would rather not sell it before lowering the noise floor anyway, though I won't be going for the whole cap upgrading, re-chipping and so-on. Are there certain caps on the channels (even just 1-16, my most-used) and in the master that would address the noise, without having to replace all of them? I reckon I'd be smart to start with the PSU caps and see what that does?
