Well that's why we were all flustered a bit when you were pushing ATR so hard last year...+5000 doesn't mean a hoot if the bias amps can't muster the levels to properly bias the tape. AFAIK, like Beck said, the 38's bias amps are setup to work with +6 tape. I would wager that, at best, they might be able to bias +9 tape but it'd be just barely, and I bet they can't.
And again, the reason to use such tape is to open up the door to avoiding noise reduction...getting higher output tape actually HURTS you if you are going for saturation artifacts. You want saturation? Then get tape that saturates at lower levels and then you aren't straining your amplifier electronics.
I've ascertained that my Ampex MM-1000 can bias +9 tape without cooking the bias amps...I will still set it up for maybe 355nWb/m at the MAX because there are erasure issues at higher operating levels but these are the things we should be thinking about when learning to setup our machines...work within and capitalize on the limitations of the machine rather than trying to keep up with the Jones...Now, I think that's pretty phenomenal that my 40 year old Ampex can properly bias +9 tape when it was made in a +0 era...that's overbuilt...and the electronics have plenty of headroom to push +9 tape, but that doesn't mean any older machine can do that.
Do you realize how many of your favorite hits were recorded on +3 or +6 tape on a machine set at 250nWb/m or 185 for that matter? +9 tape is certianly a nice option if the machine can really take advantage of it but I guarantee there are people whacking out their machines getting "PHAT" sounds off of +9 tape when what they are really hearing is distortion artifacts from underbiased tape and distorting amplifier electronics. Its a minor injustice to tape AFAIC.
