SouthSIDE Glen
independentrecording.net
Agreed. I'm just kinda shaking the branches to see what might fall out.Although if he's missing the high freqs in his analyzer in the DAW (presumably?) then this might not be the case in this instance.
G.
I was actually starting to wonder about this, based on your earlier responses. Thanks for the clarification. This is a possibility. Do the instruments sound duller when you listen to them "live" in that room?I think I need to clarify something. When I speculated that I have too much high frequency absorption, I was talking about in my tracking room--not in my mixing room. I was wondering if too much high frequency absorption in the tracking room might cause the room to sound too dead, so that the instruments that I'm recording sound dull. But now I understand why you guys replied the way you did.
As I said earlier, even if you recorded in an anechoic chamber, you should not be rolling off so badly so far down the frequency spectrum. You can't have reflections of frequencies above 10k if the instruments are not generating those frequencies to begin with.I think I need to clarify something. When I speculated that I have too much high frequency absorption, I was talking about in my tracking room--not in my mixing room. I was wondering if too much high frequency absorption in the tracking room might cause the room to sound too dead, so that the instruments that I'm recording sound dull. But now I understand why you guys replied the way you did.
Ok, I think maybe I've figured this out. I ran some tests by engaging a high-pass filter and ran the frequency up to around 9 or 10 kHz while playing some of my reference tracks that I imported from a commercial CD. The only thing that I could hear: the hi-hat.
When I'm recording, I don't typically use a dedicated hi-hat mic on a track by itself, because I've always found that I can usually hear enough of it in the overheads and from the leakage into the drum mics. So it would appear that the commercial CD's that I've been using as a reference most likely have a dedicated hi-hat mic, and they've got it cranked enough to make it louder in their mix than what I would typically have in my own mixes.
The overheads you are using do have a more distinct rolloff when you use the omni-pattern but it's there for a reason. Check to see which you are using. The cardoid capsules don't roll off the same and if you are already using one check to make sure you don't have the -10db pad. If you do, try it without because the pad colours the sound a bit. Use the setup that sounds best to you.Ok, I think maybe I've figured this out. I ran some tests by engaging a high-pass filter and ran the frequency up to around 9 or 10 kHz while playing some of my reference tracks that I imported from a commercial CD. The only thing that I could hear: the hi-hat.
with the Recorderman setup, you get a lot of snare and toms in the overheads, too (almost too much when I crank them up).
another thing to kind of think about which is just as important as the room your in, is the bass proximity effect. You might be recording to closely to your source which is causing it to be too much low end. I think I'm a shooter in the dark with that statement but I had issues with recording screams and once I told him to back off the mic about 3 feet or so, It sounded much better and far less low end with equal silky top end as I got when he was closer.
Or re-assess how hard you hit the hi-hat.If you're lacking hi-hat in your mix, then you should re-assess how you're micing your drums.
DING DING DING DING DING !!!Put a single mic 10 feet away from the drum kit and record the drummer. Play it back for him. Let him hear how he "mixes" his drums.
