silentsky
Member
My mixes seem to really be lacking in high frequencies when I compare them to commercial recordings. When I look at a spectrum analyzer, the high frequencies fall off sharply around 9 or 10 kHZ on my mixes, whereas there seems to be a lot of energy up there on the commerical CD's.
My question is--how do I rectify this? Do I need to compensate by boosting the highs using EQ? If so, should I do it only for selected instruments when mixing (if so, which ones), or should I use the Master EQ in my mixer to EQ the whole mix?
Could it be that my room is over-treated? My room is treated with Ready Acoustics Ready Bags. I've got 4" traps in the corners from floor to ceiling and 2" traps spread out over the the walls and ceilings. I've got an 8-foot ceiling, which I've also read can be one of the causes of this.
BTW, I'm mixing In The Box. Would it help to try mixing Out of the Box instead? I'm open to any and all suggestions.
