miroslav
Cosmic Cowboy
I’ve always been intrigued by Jimmy Page’s low slung guitar position. I know he’s not the only one to do that, but most times it’s the young guys that will do that…and then at some point they realize it’s very awkward and even bad for your wrist to play like that…yet Jimmy Page has never changed, and he works the fretboard pretty darn good for such an awkward hold….I mean, he ain’t just playing some punk rock chords, which you can get away with on a low slung guitar.
Here’s a couple of images:
Just for a goof…I’ve experimented with that low slung playing position just to see how much you can pull off…and man, it’s not easy!
I notice that Page also tends to angle the neck way up high, which makes it easier to play up toward the headstock even with the guitar slung low…but when you come down towards the 12th fret…your wrist really gets a nasty kink! OUCH!
And it’s not just the fretting hand…as his strumming hand is really stretched out down low, which makes it hard to work with a lot of up/down picking…he has almost no support for his right hand, like one might get by placing the palm on the bridge, etc. with a bend at the elbow, which is a more flexible and stronger arm position.
Anyway…as I’m a major fan of Jimmy Page…it’s just a curiosity for me how come he preferred to play in that position (other than it looks real cool
I like the guitar up higher…so that the neck is almost parallel to the floor, with only a slight upward tilt of the headstock, and when it’s in that position, I raise my guitar so that my arm makes almost a 90 degree bend at the elbow when I’m holding the fretboard at about the 8th fret…halfway up/down the neck.
I’ve tried many other positions…and I always come back to that.
).I like the guitar up higher…so that the neck is almost parallel to the floor, with only a slight upward tilt of the headstock, and when it’s in that position, I raise my guitar so that my arm makes almost a 90 degree bend at the elbow when I’m holding the fretboard at about the 8th fret…halfway up/down the neck.
