M
mk_re
hey guys.. just wondering - what type of speakers would these be, the large ones that are mounted on the wall behind the monitors?
I had a set for about a decade. I could mix on them just fine, I just didn't like it. You have to mix at a low level to keep your ears from burning out and to keep the response somewhat usefull.They are a tool...if you can make mixes sound good on NS10s...they will sound good on just about anything...some people here dont have the skill it takes to use them.![]()
Unfortunately, you have just been horribly misinformed as to their purpose and history. The original versions weren't even marketed as studio monitors, they were bookshelf speakers. It wasn't until someone famous decided to replace their auratones with these things (and everyone copied him) that Yamaha started marketing them as 'studio monitors'.
It doesn't take any more skill to mix on NS-10's, and you aren't any more of a man for forcing yourself to use them.
I have never been to a real studio where they were the only speaker.And yet Ive been in many studios where they are the only set...
Regarding the "Big Speakers" - I've always thought those were mainly to impress clients......ie: blast thier recording back at them through big speakers that can make almost any mix sound good![]()
The HZ speakers are most likely Quested HM's. Around $75,000 each.
Can't see any detail in the other two. I see some Tannoy Eclipses on the rail in the bottom photo...
Really? I've only been to one studio, that wasn't a mastering house, that had B&W's for mains. Most of the ones I've been to are using Ausbergers, Meyers or Questeds. Back in the day, everyone had Urei's.Yes they are...most studios use B&Ws for that...
Look at the last post, it is a frequency plot of an NS-10. https://homerecording.com/bbs/showthread.php?t=285391&page=2NS10s register flat across the frequency spectrum...if you have a modulator and a level meter...you can see that.
If that were true, you would see studios filled with high powered Bose systems. They certainly wouldn't spend tens of thousands of dollars on purpose built speakers just to blow someone's hair back. You could do that with just about anything.Regarding the "Big Speakers" - I've always thought those were mainly to impress clients......ie: blast thier recording back at them through big speakers that can make almost any mix sound good![]()
