S
second skin
BEAT IT!
Ok drossfile, I will try recorderman again and see if somethings up. Maybe you could listen to the song "Crash and Burn" on my bands myspace and see what you think of the overheads it was done in recorderman form.
www.myspace.com/themedicationband
or a high quality mp3
http://files.filefront.com/Crash+And+Burnmp3/;13388974;/fileinfo.html
Thanks everyone for all of the advice. Oh and second skin this is what I am using:
Interface is presonus firepod
mics are:
kick - cad drum kit (going to be sample replaced)
snare - sm57 (mixed with samples)
toms - cad drum kit (going to be sample replaced)
HH mxl 991
ride mxl 990
OH akg 451's
and I have an extra input slot and a pg48 to do something with if needed.
Again, what do you guys think of spaced pair? Any tips for setting it up? Thanks so much.
whenever i do a spaced pair i place one over each side of the kit. then listen to make sure the kit sounds balanced in the spaced pair and adjust the gain on the two preamps so that they are even on your meters. i'll also have the drummer play kick and snare nice and slow so that i can make sure that they fall in the center of the stereo field. if they don't you will have to move one of the mics around.
no matter which method you use the important thing is to get the kit to sound as good as you can in the room. once the kit sounds nice then you can find the overhead approach that you want. get it sounding good in the overheads and everything else is secondary from there.
). To Second Skin, Thanks for that explanation of setting up spaced pairs I will try that. To Drossfile, that is weird everything is ok on my end.
