antichef
pornk rock
OK, I got bored - I took off the lid of my ACMP-81 pres and messed with the hum issue. I recorded my messing with one of them - here's the mp3 file along with some observations.
*TURN DOWN YOUR MONITORS BEFORE LISTENTING* -- I have everything boosted up, and then for some reason, the mp3 export "normalized" it way up again.
The EQ stage is engaged the whole time. There are two circuit boards that have inductors on them, and these, along with the toroidal power transformer, seem to be involved. Each of those boards (like the others) has a gain pot that's adjustable on the front.
I found that if I turn each of those pots down almost (but not quite!) all the way, the hum reduces down to a much lower level -- that's the first thing you'll hear -- the hum decreases first when I turn one pot down, then the other. Next, I put some twisty pressure on the toroidal transformer and the hum goes away completely. Then I cut to another take, where both pots are back at 12 o'clock, and I do the same thing with the toroidal transformer, and the big hum goes away completely.
Wish that was the end of the story -- I was able to back off from the unit and have it be quiet, but it was real touchy - when I moved it, the hum came back, and then as I messed with the toroidal, eventually it refused to go away at all, and now spinning/moving/unbolting/removing/flipping/hanging-outside etc. the toroidal has no effect on the hum at all. The effect of reduction when I turn those two pots down is still there, though.
Wrapping the toroidal transformer in mu-metal peel & stick has no effect. Same with the inductors. (careful with that stuff, btw, I cut the crap out my fingers with its sharp edges and didn't even notice until I saw the blood).
On one of my units, there's a brass screw missing from one of the inductors -- maybe someone was looking at it before me. Doesn't seem to make any difference on sound or hum, though.
Anyway, I have some replacement transistors on the way, and under normal operating conditions, the hum is really low for me anyway.
