Monkey Allen
Fork and spoon operator
Hi...I have a question about acoustic guitar intonation...but first some background...
I own a Taylor 110 and a Martin DX1...basically in the level just above cheapskate when it comes to buying guitars. Sometimes I really want to smash them because they have intonation and tuning problems. The low e will be sharp at the 12th compared to open...the b string will be the same.
Anyway...correct me if I am wrong...if there is a discrepancy between the pitch of the open (let's say e string) and it's fretted octave at the 12th...then there is a different string length from 12th to saddle and between 12th and nut. To correct this you must adjust the distance so it is even.
I heard that the technique is to reseat the saddle...but my question is...what if you have more than just the low e string that has a dodgy length? What if when you reseat the saddle to fix the low e, suddenly the b string is out of whack? Then let's say you go back and fix that...then the e string is out...possibly the g string...etc?
I'm lead to believe that the 12th fret should mark the exact midway of the string...but how can that be when saddles are not uniform...they are set back and forth per string.
Where does string height come into play?
If I string my guitar with a size string that the manufacurer says are not recommened, have I hurt the intonation?
Why when I take my guitar to be set up does it come back as thuogh the tech never touched it? Well that's probably because he didn't....which is why I want to learn it myself.
So anyway...any links or advice would be great. Thanks.
