pohaku
Fender Concert from the early 80's . These amps all came from the Rivera design board. They dont sound bad at all............
Yup, that's the Concert II.
I have a '77 Super Twin Reverb also from Riveras hand...The overdrive pot got re-named "The Suck Knob" because it truly does.
My small amp is a Epi Valve Special....all tube 5 watt but ditch the stock speaker...I haven't yet but I plan to.
I'm pretty sure that would be the Deluxe/Deluxe Reverb. Two 6V6s, 22 watts. Lovely amps. You'd have to do channel switching with an external box, though.
I recently got a Fender Jazzmaster Ultralight. If you can overcome your prejudice against solid state, it's a terrific sounding amp and has the features you want.
Very interesting, considering your stated amp history. Do you play clean or with overdrive. If the latter, do you turn the jazzmaster up to achieve distortion or used external pedals. I have a Fender solid-state Champion 30 that sounds just fine when playing clean or using the amps' overdrive function, but turn it up when using the clean model and it sounds extremely crappy in the same way that solid state amps always sound to me.
(Also ..... Supro and a Silvertone Twin 12 indeed! ... I'm flashing back to the sound of surf music and visions of Annette Funicello's bosum. eiiiiihahahahahahahahaha wipe out!!!!!! [cue jostling the Twin 12 head])
I can't remember what I did with my Silvertone after I graduated to a Super Reverb. Sold that and got a Marshall "100W" stack (1972 watts) with 2 4x12 cabs -- big mistake - used it a couple times for gigs outdoors and in gyms, but couldn't tone it down enough for clubs (no drive channels in those days). Had to downgrade power wise quickly to an Ampeg B-25 and Sunn 1200s cab when we started working clubs regularly. Still have both of those, but use them only for bass if a friend comes over to jam. The small Fender 27W works fine at basement volumes, and is a good match for the Strat. I could probably get by with it in a small club if I ever lose my mind and start doing that again.
Pro Junior all the way. They're cheap and they sound amazing. After that, the Hot Rod Deluxe is a good amp, especially if you put a good speaker in, but if you have the money, the Deluxe Reverb or the Princeton are wonderful.
Don't have an answer. I'm just bumping this so it stays at the top--I want to hear some answers too.
I'll piggy back and modify your question a bit too: what about a one-channel amp? Something just clean, but small enough to crank and get the natural Fender break up?
Quoting myself here, 'cause I answered my own question--or at least jumped in and tried one.
I picked up a Blues Jr. earlier today. I'll have more time to play (& maybe track a bit) with it tonight. So I'll start a new thread with some results then...)
Very cool Tony...I hope to enjoy my new baby for a lot of years.
It's Saturday, and I've got an electrical circuit to run for a new light, drywall to put up in the garage, a car to work on....BUT....I just had to slap a 57 in front of the new Blues Jr. and see how it sounds tracked. I've got to play around and find the sweet settings on the amp and play with mic placement etc, for a quickie on a brand new (to me) amp, I'm liking it:
Congrats on a fine amp.
