R
rush1974
hi guys and sorry for all these post . . just a few things that are confusing me . i managed to find some pic from the forums and i'll put them up so that you guys can see what i'm trying to ask . again these are not my pic and i'm just trying to understand the terms and some clarification .
pic # 1 :
do you call this foam or insulation . i guess this goes behind the drywall in between the joists . and can this be used for making your own bass traps . meaning build a frame and put this foam or insulation inside and cover up with fabric . i'm not sure what this 703 looks like or is this 703 but the itchy stuff that you get from your local home depot store which you put in between your joists, can you put that insulation into a frame and make up your own bass traps or sound absorbers . .
pic #2 :
What exactly do you call this . sound absorbers or diffusors or foam or ?? and do you have to put a lot of these on your walls . (BTW all this info i need is for my control room that i'm trying to build size 13' x 9' with 7' celing)
pic #3:
i see some guys are building their monitors inside a wall as you can see one person was doing in his/her studio while others are not putting their monitors inside a wall but ontop of a desk or stand with sound absorbers or foam around that area as you can see in pic #4 .
what is the advantage or disadvantage or is it better to build a new wall and place the monitors inside there. and in pic #3 when this person's studio was finished i didn't see any of those foam (in pic#2) anywhere on the walls .
also in pic #3, where the monitors are placed inside a wall what kind of stuff is behind the wall . I mean is it hollow or open in there or that behind is stuff with insulation or foam or ???
pic #4:
as mentioned above, is it a good idea to go like pic #3 and have your monitors in the control room insde the wall or like pic#4 on top of a desk with absorbers hanging or foam . .
sorry guys if i put up your pics without asking but i though this would be a better way for me to ask quesitons and understand a lot of this . looking at your pics make things clear to me and helps me understanding too . .
thanks
pic # 1 :
pic #2 :
pic #3:
pic #4:
thanks
Sounds terrific. Although, untill I can afford REAL studio monitors that CAN be soffit mounted, this will have to do. I do have small studio nearfields on my console bridge. Mostly, I use my soffit mounted speakers to LISTEN TO MUSIC!!
