jeffmaher
I think the poster means he uses the compression for "de-essing" ...not "hiss"?
It shouldn't be. It's wrong. As far as a pad goes, it's not reducing hiss, it's simply turning down the output of the mic. So, of course you think you're getting less hiss. Turn it back up to the volume it was before you put on the pad, same hiss.
Ok, I was just making sure I was reading into this right.
Because if a pad decreases the output of the mic, in turn it also decreases the signal-to-noise ratio. Which in this case is exactly opposite the desired result... Correct?
well the thing is the compressor is used to kill any hiss, (the expander on it)
The inherent SNR of the mixer, the mic, the preamp, etc., respectively don't change.
Exactly my point. If you leave the noise floor at a constant AND attenuate the wanted signal, then naturally the SNR will decrease.
LOL my problem isnt hiss lol i just said i use comressors expander to get rid of any unwanted some MY PROBLEM IS that wen i use dyanmic processing within cool edit pro, most ppl say i shud use 4:1 very fast attack BUT my vocals take a drastic change as they are all evened out. they become very dull and so. i was hoping if someone could tell me hoe 2 maintain that sound after compression. i have access to waves and izotopez, any1 know any settingsSorry no advice.
Just wanna congratulate you with the missleading thread title of the year
Your award is any choice of 100 dollar mics for rap vocals
Merry x-mas![]()
While we're on the subject....what's the best mic for raping for under $100?
You're on a roll with this thread....i was hoping if someone could tell me hoe...
um, thats spelled "rapping", i dont think you will get many rape fans here
9 out of 10 rapists agree, shure makes the best mic for rape, the sm58. It's rock solid and could knock out, and incapacitate your victim with one blow to the head, then, after you've violated, beat up, or murdered your victim, you can take it back to the studio, and it will work just like it always did, without any dents and scratches....beautiful thing, the sm58.
