export error....
  • Thread starter Thread starter buryher17
B
buryher17
please sombody help, i am using cubase le the version that came with my tascam fw 1082, and the export featur says theres an error but not why it wont work...
please help
thanks in advanced
Did you mark what you want exported? To do this, you drag those little blue arrows above the numbers towards the top of the screen. Drag one to the beginning and the other to the end.
no i didnt actually. thank you, i will try that when im back at home and see if it works.
Failing that, post up a screen shot of the error message
ok i tried it, and it does export now expect now its only like 4 kb size and its 0 seconds and is nothing...
i put the cursers form start to finish, i higlighted it all, i bounced it.... what am i doing wrong.. i need to know by the next like half hour
make sure that the little arrows on top high light the selected area BLUE, and NOT red, ... you may have the arrows reversed... try that, and also try cntrl+a on all the tracks to highlight them as well as the time markers.
good luck
good luck
ok FINLLY i got it!
i had to do the drag think with the pencil above. i bounced it and got the right brackets.
thanks so much guys. you saved me. i really needed to figure this out in time
