B
Beck
Guest
I dont mean to hijack this thread, but the more i try to understand digital/analog hybrids and all this stuff the less i care to get what i want out of a recording setup. Its hilarious to me that in the year 2007 with all this shit people know about recording there is no easy way to record something the way you want. There is always a ton of hassle and then you end up sacrificing some flexibility in the end anyways. Actually i guess it ISNT hilarious to me, more painful really because it shouldnt take a million thought out calculations and strange processes and wiring schemes just to record a lousy tape while the computer records it.
It is UNBELIEVABLE how hard it is to have something be easy enough to use yet flexible enough to allow you some room to alter and adapt your recorded work. There are a thousand ridiculous pitfalls that logic should have eliminated in the design phase long ago.
OK im done
People make this too hard. I think it has more to do with not knowing what’s available rather than it not being available. I’ve been using some form of synchronization since 1984. IMO, forget the so-called “Front end” method of incorporating analog with your DAW.
Sure, people happily do it that way and simply adjust the timing on the digital side. However, as an analog purist I wouldn’t do it that way and don’t recommend it. Every time you manipulate a file ITB you corrupt it (again, this is from an analog purist approach, so you all will just have to live with the fact that’s who I am as you consider my input).
If you’re going to the trouble of going to tape first you’re not going to want to then hack the file to pieces with digital manipulation. You’ll be undoing some of what you went to the trouble of laying tracks to analog in the first place.
Everything in my studio runs in sync using SMPTE and/or MTC as one truly integrated hybrid system. For example tracks I lay down on my PC are just tracks. Same thing when I had an ADAT. There are no timing issues. My reel-to-reel, PC, and outboard MIDI devices all run in sync, so I can bounce whatever I track in analog to DAW and vice versa (if I so desired).
There are tons of inexpensive sync boxes for every configuration you can imagine and most good recording software is capable of master or slave… even Pro Tools Free, for gosh sakes.
The web is full of info on synchronization. Check out the EM article by Dan Phillips for starters.
http://emusician.com/tutorials/Get_in_Sync/
