B
boblob
Just picked up an MT3X as an upgrade to my trusty little Fostex X-24 and have a couple of questions.
When recording and listening on the monitor ("PHONES SELECT" set to "MONITOR"), it seems to be only recording on the left or right channel on each track. Strangely to me it alternates between left and right depending on which track you use (ie - track one only records on the left, track 2 only on the right).
When the "PHONES SELECT" is set to "STEREO" (listening to the mixer output), everything seems fine - the pan knobs work as they should.
Not sure if it's broken or "user error" on my part (and yes, I have read the manual, but find it a bit vague as to what's supposed to happen).
I assume the MT series all work the same, so any guidance would be much appreciated.
