Blue Jinn
Rider of the ARPocalypse
Kinda dumb question here, but I believe the KT-2A is designed for "pro" level +4dBu in and out. Is there really a problem using it on "prosumer" -10dBm signal path, or should I bring the level up on the input and back down on the output.? I've had advice that it's fine either way, but would work better bringing the level up, as the compression is dictated by "how hard you hit it." (The level amp would probably have a lower output impedance too.) Looking for opinions/advice.
TIA.
TIA.
