H
HydrantC12
can someone link me to a site where i can buy a X-Y mic clip. I cant seem to find one. You know the clip that has 2 mic holders to record X-Y. thanks
It's enough width for mics that have a straight shaft body and can be pulled back so the clips are up near the head. The tilt knuckle is also a very handy feature.DJL said:That holder may not be wide enough (and etc) to correctly mount two mics in an X/Y placement.... I think that holder is more for holding two mics on a podium.
And you could put the mics in the clips backwards which could help... however, for a correct X/Y mic placement one mic capsule should be placed over the top of other so you would need to use a spacer or whatever to make that holder work for X/Y placement. I think he would be better off getting a real stereo bar.mixsit said:It's enough width for mics that have a straight shaft body and can be pulled back so the clips are up near the head. The tilt knuckle is also a very handy feature.
Yes, it matters... and you should place one over the other... there is a picture on this link http://www.dpamicrophones.com/eng_pub/ check it out.mixsit said:Does it matter if you cross them over by angling them above and below each other -or just set them face to face?
Wayne
Yeah, that will work... thanks for the link Dave. Oh, and here is a 19mm spacer http://www.dpamicrophones.com/eng_pub/DaveSweet said:I use that same two-mic mount thing - BUT, if you want to do x-y, you need to raise one mic slightly above the other - I used this: http://www.musiciansfriend.com/srs7/g=home/search/detail/base_id/38711 works like a charm, if you've got pencil condensor-type mics that fit...
I think it's safe to say in behalf of everyone on this thread... your welcome HydrantC12... and have fun.HydrantC12 said:i really appreciate all the input guys
