RideTheCrash
Member
Hmm, and is the wiring going to be any different than what was suggested if that is the case?
You're probably right. I didn't look that carefully at your configuration. Since it was an RCA on one end, I assumed that it was an RCA on the other. Still, it doesn't really make any difference - the two are exactly the same except for the connector at the unbalanced source end. For our purposes, there is no difference whatsoever between an RCA plug and a quarter-inch Tip-Sleeve connector.RideTheCrash said:Not sure what you meant by #17, wouldn't it be #13, because I'm going from a 1/4" TS to a male RCA (as of now), but it's the RCA I want to change to XLR.
