O.K I got offline & messed about abit, the record enable was a mistake on my part, you only need to do THAT if you are triggering a vsti or other external gear via an external controller,
record enable activates MIDI THRU .
Every thing else is dead on accurate, i.e yes Subtractor, I can just drop [import] any midi file, & set it up as described and it WILL work, but not until you specify the output source for the midi track, the easiest way is to: open a new project, empty, create one midi track [just to simplify this for now] ,then hit f3 to bring up the vst mixer, at this point it may be helpful to click the little arrow at the top of the midi track & select WIDE [makes it easier to see text labels,etc.] Depending on what you have chosen in the device setup/midi, you will see your midi in label at the top of the track, anyway forget about the midi in for now, you just want to play an imported file..so look at the bottom of the midi track & you will see 2 things, the track name, i.e midi 1, and below that you will see the output selection, click on this and you should see [based on your sound card/selected vsti's/attached hardware midi in& out, eg. my midisport 2 by 2] all of your OUTPUT options.
I can either select my T.BEACH general midi, OR A VSTI usually the latter.
thats it, tombuur, are you doing this?, and also have you gone in & setup all of your audio/midi devices,etc.?
Just thought of one thing tombuur, do as I 've instructed, but after setting up the midi track & importing the file to it, hit F11 [vsti rack] and select one of SX'S included vsti's, it should now appear in the output selection list at the bottom of the midi track, see if you can get any sound out of one of those.
Subtractor, I 'll give your midi file a shot , be back later.
tombuur don't give up man we can help you figure out the problem.
Shreadzilla
