Whatmysay said:
If time slices is not the issue then what about the claims of 1-bit recording with mega high sample rates
<snip>
The 1 bit formats are a very different technology. Everything in this thread until now was talking about Pulse Code Modulation digital audio.
I'm not so sure about manufacturers playing onto naivety, but I haven't heard DSD yet either. Direct Stream Digital is the technology behind Super Audio Compact Disc. 1-bit, non PCM audio. It might be a great thing if such a format takes off later on because it's supposed to sound pretty good.
Every computer recording setup for the most part is PCM digital. I don't think anyone's come up with wave editing or plugin capability for DSD systems. You can record and play back, that's it. It's still a very new technology compared to PCM, but it looks promising so far.
Different can of worms than PCM.
Sample rates in PCM are relevant to what people like SSG have been talking about. The frequencies you're capable of recording. Once you're beyond the range of human hearing, what else is there? It takes a lot more processing power to accurately reproduce 80 KHz, but we can't hear it, so why use it?
As to how the software deals with the gaps, it isn't the software. It's the converter, and it's the PCM process. If you were to line up 2000 samples, each one of them individually would look like a small spike. It won't give you anywhere near enough information to reproduce a sound. So if you've got 2000 of them, essentially you've got 2000 very small spikes. But that's not how they come out. They interact with each other by phase relationships and bend. Kind of like what a magnet does to an electrical field, or the way a prism bends light. The samples don't come up with a connect-the-dots facsimile of the original wave. They reconstruct the original wave in all its detail. (At least they're supposed to, which brings up the overall quality of the conversion process, thus the converters. Good ones cost more for a reason, and it doesn't have much to do with sample rate anymore). The limit on what frequencies they can reproduce is the Nyquist limit. Whatever falls in "the gaps" and can't be reproduced accurately (higher frequencies) is filtered out.
Higher frequencis require more samples, so you have to run the process fast enough to cover human hearing, and the capabilities and limits of our mics and speakers.
sl
