G
Gillette
Sure, it makes sense to try some "cleaner" power (maybe that is the reason why my Gain knob doesn't have much power so I have to turn it pretty much 3 o'clock to have some decent signal)
Before that, just one more thing.
You said this
"Now, your keyboard has line outputs so if you had an audio interface with a spare pair of line inputs you could hook up that way.
If this keyboard does midi control + data via USB you could carry on using that without issue."
Let's say that even new interface may have some noise problem if PC's usb power isn't enough.
And let's say that some USB hub would be useful for that interface too and hopefully solve that issue.
Then it would be ok to 1) hook up my keyboard to the new interface with let's say ..TS cables (out/in) and to 2) left old keyboard connected to the PC via his USB cable (for data connection) ?
Or it's better to 3) forget about its USB cable and look for the interface that has both Line inputs and Midi inputs (so I can hook up keyboard to the interface via midi cable) ?
I'am asking this because of possible drivers conflicts
You said this
