Which phaser?
  • Thread starter Thread starter Strat Man
Strat Man
I'm currently trying to build up my pedal board with some more sounds, I'm in a more is better phase. Refusing to get multi effects so buying one by one. Currently my set up is:
Fender USA Toronado > Boss TU2 tuner > 535Q Wah > Boss GE7 EQ > Boss BF2 flanger > Ibanez DE7 delay > Mesa Boogie Dual Rectifier Solo head.
Looking at getting a phaser and chorus next. Suggestions for both would be appreciated. Phaser I was looking at going traditional getting either a Small Stone or Phase 90, suggestions between the two, others?
Probably gonna just get a boss chorus but again any suggestions are welcome.
Also any other ideas for what else should hit the board would be great.
My bands sound: www.inverseorder.co.nz
- Neill
i'm using a Danelectro Phaser at the moment. the little dark blue one (i forget the really bad name they've given it...) its nothing special, but its better than some of my other pedals - if i want to add something to a solo, i'd probably reach for it. plus, it was dirt cheap :p it probably wouldn't sound as good as your other pedals.
i use phaser effects a lot, and i'm probably going to get a Small stone come summer after we've gigged a lot, i've got some money and some time to play guitar. after using the danelectro, i'm pretty used to the 'one knob changes everything' type of phaser effect :p. i'm going to look into this phase 90 doo-dah first though.
to sum up - i don't know, but i know not to go for the danelectro, which you didn't seem to be thinking about anyway :confused: :o
andy :)
alex_n said:
what if you plug it in backwards?
it still works but all of the swooshing goes in reverse before you even play it.
I have to agree with the people saying the phase 90, but, realistically in that case you may want to look at the phase 100 instead.
The only real problem with the phase 90 is that its maybe a bit too aggressive sounding. By that I mean there is no option to mix in how much signal you want compared to the original signal.
I'd like to get someone to design a phase 360 for me...I'm thinking the 180 probably wouldn't sound so good. :D
